Help! Idle at 3000rpm after head gasket job
Old Dec 16, 2009 | 03:00 PM
scubaman's Avatar
Default Help! Idle at 3000rpm after head gasket job
I just finished replacing the head gaskets on my 2000 DII with 110K. When I started the engine, it jumped to 3000 rpm and won't come down. I shut down the engine after 1-2 min. and checked all the hoses and connectors. Everything seems to be secured and connected to the right places. I started the engine again and it still idle at 3000rpm.
Can somebody help me diagnose this problem? A list of steps to take and procedure will be greatly appreciated...
Old Dec 16, 2009 | 05:24 PM
tweakrover's Avatar
Mine did the same, it got gradually better over a few days. I figured it was all the sprays for cleaning and lube mixed with the computer reseting. Run it out on the road for a bit. Oh yea check for vac leaks first to make sure, but it should clear up completly in a few days.
Old Dec 16, 2009 | 07:41 PM
Mrmerlin's Avatar
what happens if you disconnect the throttle cable from the manifold?? could the cable possibly be caught somewhere to cause it to not have enough slack??
Vokam03Disco
Jun 16, 2013 09:54 AM
lyleorszulak807
Oct 17, 2010 11:07 PM
baburhan
Oct 2, 2010 03:23 PM
blast20
Aug 2, 2010 09:02 PM
momentum59
Jul 20, 2010 07:40 AM
