Help M A P sensor location 2004 disco 2
Old Jul 12, 2021 | 04:05 PM
The Deputy's Avatar
https://www.autocodes.com/p1129_land-rover.html
Old Jul 12, 2021 | 04:32 PM
Maxwell_land's Avatar
Thank you so much for taking time to help a nuby to the disco life I'll use the website and go from there with the necessary repairs
Old Jul 13, 2021 | 08:43 AM
mollusc's Avatar
Originally Posted by Maxwell_land
I sprayed vac line with starter fluid to try and find a leak but rpms didn't rise maybe the cylinoid needs to be replaced
The SAI system has its own set of vacuum lines.
Old Jul 13, 2021 | 10:08 AM
Okay when I get home I'll have to check those cause I checked all the ones on the intake side of things
Old Jul 13, 2021 | 10:22 AM
Is the SAI in control of the gas fume lines
Old Jul 13, 2021 | 11:02 AM
Red5's Avatar
No, that's a separate system with its own purge valve. None of the codes you mention though are related to this valve though.
Old Jul 13, 2021 | 11:07 AM
Okay thanks
journeyman
Nov 20, 2023 04:13 PM
Maxwell_land
Jul 12, 2021 04:09 PM
dustinkantu
Oct 2, 2016 10:32 PM
thehun
Oct 5, 2011 11:21 PM
wielgoshoff
Engine & Internal
Mar 18, 2008 11:37 AM
