Help ME!! Intake manifold removal
Old Jan 25, 2017 | 05:59 PM
twin6's Avatar
Default Help ME!! Intake manifold removal
Disco II.
We removed all 12 bolts in sequence from the manual and are at the step where it simply says "Remove inlet manifold". How do we pry that bad boy off without breaking anything? I put a pry bar in the head of the front valley gasket bolt head and tried to pry up the manifold but it will not release.
I know the four bolts are off of the coil but the injectors and fuel bar are still in (injectors are disconnected).
What to do???
Old Jan 25, 2017 | 06:01 PM
Luckyjayb's Avatar
Originally Posted by twin6
Disco II.
What to do???
also check to make sure you have disconnected the rear fuel line to the fuel rail. That will hang you up. It should easily come up but somebody might have put a good bit of sealant on it keeping it on snug
twin6
Jan 26, 2017 03:22 PM
jsyonker
Nov 12, 2012 09:15 PM
maxellfullmoon
Jul 26, 2010 09:09 PM
roverwoody
Sep 9, 2008 10:12 AM
carl.plansky
Aug 24, 2008 11:35 PM
