Help my land rover keeps turning off
Old Jul 10, 2018 | 08:13 PM
saltyseth677's Avatar
Default Help my land rover keeps turning off
My 2000 land rover discovery starts up and drives just fine but when i slow down or come to a stop it wants to or does die on me. Any help would be appreciated trying to fix myself thanks.
Old Jul 11, 2018 | 02:50 AM
The Deputy's Avatar
Are you getting a check engine light/codes? Maybe a bad tank of fuel? Does it stumble/run rough right before it dies?...or just shut off like someone turned the key off? Does it start right back up? Did this symptom start suddenly or has it been getting worse over time? What have you done to the rover lately, any type of repairs?
Brian.
Old Jul 11, 2018 | 06:58 AM
Brian.
yes the check engine light is on it does sort of stumble right before it turns off I can immediately start it right back on. I've only had it for going on three months so I've personal have no repairs just maintenace
Old Jul 11, 2018 | 09:02 PM
redwhitekat's Avatar
Start by reading the codes you should have a ultra guage always checking the temps etc and the ultra guage will read your engine codes
Old Jul 20, 2018 | 10:57 PM
robersonb's Avatar
Crank position sensor will do that too. Then it will start up after it cools down. Take to autozone. Ultra gauge is a reasonable one to buy to have on hand. That way you can also watch your temperature. With the aluminum heads, by the time the gauge tells you its hot your already damaging it. It won't do ABS but it will read all your engine codes and you can clear them.
Old Jul 21, 2018 | 07:48 AM
The Deputy's Avatar
Yes, have the codes read and we can go from there.
Brian.
punkarockaboy
Sep 26, 2011 09:22 PM
TheRealMW2Ninja
Jul 22, 2011 12:40 PM
briskin
Sep 6, 2010 06:07 PM
smt
Mar 1, 2008 11:44 PM
mac25dm
Dec 6, 2007 03:43 PM
