help need to lock into 2 wheel drive
Old Nov 3, 2010 | 09:23 PM
elrocha69's Avatar
Default help need to lock into 2 wheel drive
Well here's the story. Went to replace a bad front u joint as they only cost 11.99 or 22.99 for a lifetime from oreilys. Found that the bearing on the double u joint was bad and can't put it back on with broken needle beaings. The spring is fine though I'm just missing a couple needle bearings.
Old Nov 3, 2010 | 09:27 PM
lipadj46's Avatar
You can't
Old Nov 3, 2010 | 10:00 PM
lordmorpheus's Avatar
Unless you have changed the transfer case, you are immobile until you have that front shaft back in. 2001.5 through 2003 had no way to lock the center differential.
Old Nov 4, 2010 | 03:26 AM
elrocha69's Avatar
Well I got the u joint replaced and it drives smooth but I am concerned about the bearing in the middle of the double u joint. It had a couple broken needle bearings so it it short about 3 or 4 but much better than. Having busted u joints. Hope it hold up till I can get my new driveshaft in.
Old Nov 4, 2010 | 07:34 AM
lipadj46's Avatar
I would not be driving around with centering ball missing 3 or 4 needle bearings but that's just me. Why not just get a new centering ball?
Old Nov 4, 2010 | 08:05 AM
STOP driving that today, anyone can tell you, you always replace the centering ball or be prepared to replace your tranny when that fails.
Old Nov 4, 2010 | 03:39 PM
elrocha69's Avatar
Thanks. I. Didn't know I could replace the center ball. I am takimg the shaft to a drveshaft place today. I just had to get it home. Thanks for the help guys.
Old Nov 12, 2010 | 04:39 AM
elrocha69's Avatar
I just got a set of 3 Precision #344 and a Precision #617 and they are on the way. I will re-build it next week. In the Mean time I am driving the bimmer. Love the BMW but opportunities to offroad always arise when I'm not in the Disco :-) Thanks for the info guys. I knew not to drive it but I was stranded and had to make it home. I will probably get a labor quote from a well trusted drive shaft shop tomorrow.
sjewell
Sep 12, 2019 11:55 AM
Prowler9876
Feb 8, 2010 05:53 PM
freelanderjames
Freelander
Dec 24, 2008 10:18 PM
BENROVERN
Nov 5, 2007 09:19 AM
