HELP PlEASE
Old Dec 22, 2025 | 04:00 PM
  #21
cwjdrake11@gmail.com's Avatar
Hey guys anymore help would be appreciated. Cylinder 5 is full of gas I noticed as I was cleaning all the carbon buildup. Fuel injector? I’ve almost got it completely apart any good kits to buy to rebuild these? The parts I have coming are injectors, oil pump and new housing / gasket, intake gasket, valley gasket , tension pulley. Anything else easy that could help while I’m in this far?
Old Dec 23, 2025 | 06:31 AM
  #22
Extinct's Avatar
Did you ever check compression? Do you have the heads off? If I remember you had low oil pressure, did you find the gears broken? So far I have not heard you found your problems.
Old Dec 23, 2025 | 01:09 PM
  #23
redrover75's Avatar
Default Injectors
I would be careful w after market injectors. I had a few bad ones and reused the originals. Hit them w 12 volts before installing to ensure they click is the least you should do before installing them.
Old Dec 26, 2025 | 08:43 AM
  #24
WaltNYC's Avatar
That thing in your hand looks to be the spacer for the oil pick up tube. Did you remove the oil pick up tube? Did you replace the oring?
adolfojbonilla
Dec 1, 2021 08:07 AM
powderhound
Sep 2, 2020 05:40 PM
RoverNube
Feb 5, 2011 12:13 PM
fx267
Nov 9, 2008 01:55 PM
wadematt
Jun 12, 2008 09:30 AM
