HELP! Stranded! Need answers about thermostat housing.
Old May 21, 2013 | 09:38 AM
SuperSport's Avatar
Also, if you don't do the flush, be sure you are using compatible coolant. If you still have the original type coolant, don't mix with another substitute, or you will end up getting plugged up. Savannah has all the info on that...
Old May 21, 2013 | 02:46 PM
ChefGabe's Avatar
All is well! New thermostat installed, system bled, and the Disco is back on the road! The whole repair took 20 minutes, finding the part (the right one) took 24 hours! Thanks for all the help!
Cheers,
Gabe
Old May 21, 2013 | 06:28 PM
coors's Avatar
Cheers,
Gabe
Glad to hear it all worked out. Listen carefully to what we on here describe as a waterfall/rushing water type noise under your glove-box. If you hear this "waterfall/rushing water" noise you still have air in the system and you will need to re-bled. Hopefully, all is well
formel3
Jul 4, 2013 02:17 PM
DrakeB
May 16, 2011 02:40 AM
jycsalas
Jun 4, 2010 10:34 PM
ouch99
Jan 10, 2009 10:24 AM
johnnybob06
Sep 23, 2007 09:17 PM
