Help!!! with Tie Rod removal
Old May 26, 2007 | 01:09 PM
cbwhitley's Avatar
Default Help!!! with Tie Rod removal
I am in the process ofreplacing my steering box. In order do to so you must remove the tie rodend from the steering box . I amalso going to replace thetie rod ends while i am at it. I cant get the tie rods off. Ipulled the pin, removed the nut andattempted toseparate the tie rod end from the steering armwith my tie rod fork and it wont budge. On the outer tie rod I useda hammer and it wont budge. What am i doing wrong?
Old May 27, 2007 | 08:48 PM
mburnett's Avatar
Default RE: Help!!! with Tie Rod removal
Two things I have done in the past: One - wedge your tie rod seperator in there and use an air hammer (an air chisel with a flat end tool) on the end of the screw. Two - give a wedgie again and heat the outside with a torch.
I changed one out in the Tennessee boondocks on July 3rd a couple of years ago with a crescent and a framing hammer on my F-150 after a day of ATV riding. Got real lucky on that one!
Marv
Old May 28, 2007 | 09:26 PM
okdiscoguy's Avatar
Autozone has a little fork tool with a bolt in it. It fits perfectly, and it will pop it right out.
Old May 29, 2007 | 01:14 AM
mordor110's Avatar
Yes use the tie-rod puller tool like okdiscoguy said. I've got two, they're usually less than $10 each. I've used mine 100's of times, well worth every penny! Should look like a claw/fork with a pointed bolt (to center it) in the middle. There are two or three different sizes. I use a smaller one one my Acura's/Honda's. I expect the Disco will need a larger one. If you live in an area where they salt the roads in winter soak the ball joint in WD40 for a while before hand.
Old May 29, 2007 | 06:44 PM
rinmud's Avatar
been there many times sometimes ad a litttle blue tip wrench, (torch) cover the boot with an old wet rag
Cottrell
Sep 20, 2012 01:24 PM
malmberg
Aug 9, 2009 07:57 PM
Christian_X
Oct 27, 2008 05:54 PM
ljdiscovery
Aug 4, 2008 08:57 PM
jcw
Oct 27, 2006 08:26 PM
