Hesitation when cold after changing plugs. Plus CE now on.
Old Mar 9, 2009 | 09:35 PM
Disco Fuego's Avatar
Default Hesitation when cold after changing plugs. Plus CE now on.
Question: I installed the new Magnecors yesterday and now I have some hesitation when the engine is cold. I also hosed down the engine compartment, but even if some of the wires had gotten wet yesterday, it should have all been dry now. Especially since I drove my daily 135 miles...
Any suggestions? If a wire were to be loose, I would imagine a misfire at all times, even when gdriving and when the engine is warm.
The Service Engine Soon light came on this afternoon as well, shortly after starting the car.
Thanks!
Old Mar 9, 2009 | 10:49 PM
Sorry, I meant changed wires, not plugs...
Old Mar 10, 2009 | 08:42 AM
okdiscoguy's Avatar
so you still have your old plugs in? Check your CEL to see what it says (probably mis-fire) It may point you in the direction of which wires are to blame. Then pull your plugs and check them. What kind of plugs are you running?
Old Mar 10, 2009 | 09:12 AM
Yes, still old plugs. Not sure which ones, which is why I want to replace them next weekend with Bosch 4+ plat.
If a wire is bad, could it cause a rough running engine when cold but no problems when warm?
Old Mar 10, 2009 | 09:48 AM
okdiscoguy's Avatar
It could.. get the codes read and see if it gives you a specific cylinder to look at.
Old Mar 10, 2009 | 11:04 AM
Ok, will do when I have a chance.
Funny thing is that this morning there was no hesitation at all. Cold start at 47F outside temperature. I may see if I can get a set of replacement wires just in case...
Thanks for your help!
Old Mar 10, 2009 | 11:17 AM
sloppyjoe's Avatar
i am betting one or more of your wires is not snapped on all the way.
when i did my wires the rig fired right up, but as soon as i put it in gear and tried to drive it hesitated. took the metal plumbing apart and found that i had not snapped 2 wires all the way to the coil.
Old Mar 10, 2009 | 11:54 AM
I checked them last night and they all appeared on all the way... I did not check the connection at the coil though cause I didn't have time to pull it all apart again. Maybe tonight...
OffroadFrance
Off Topic
Jan 14, 2015 04:56 PM
nhigdon11
Dec 19, 2012 08:38 PM
Snafu / Disco Fries
Apr 13, 2011 05:40 PM
shoo
Oct 26, 2010 08:00 PM
Boutins
Sep 5, 2010 06:59 PM
