HG reassembly ground strap/bracket
Old Jun 18, 2024 | 11:53 AM
PNW_disco2's Avatar
Default HG reassembly ground strap/bracket
Things got hairy during the last parts of the disassembly and now I can't find my pic showing how the bracket and grounding strap go back together
Anyone able to orient me to ground strap and bracket attachment.....
Old Jun 18, 2024 | 02:09 PM
PNW_disco2's Avatar
***Update***
Orientation of bracket solved.... Grounding harness - how does this connect to the head? I have the 10 mm nut for connecting to the firewall but confused about how the grounding harness connects to the block
crankshaft speed connector - planning to leave the CPS out of it's bracket.....
Old Jun 19, 2024 | 06:51 PM
The_OGCJR's Avatar
I didn’t reconnect mine. I forgot. But you could run a ground wire from the manifold to the firewall or frame if you want
Old Jun 19, 2024 | 11:27 PM
gecko951's Avatar
Pretty sure it actually connects to the the left rear corner of the intake manifold.
https://landroverforums.com/forum/di...p-89323/page2/
Old Jun 20, 2024 | 10:27 AM
Harvlr's Avatar
OHCJR you need to connect your ground strap. If not the electricity will find another way to ground. A common way is through the park brake cable. For small electrical loads it might not be that big of a deal, but the starter uses a lot of electricity every time.
Old Jun 20, 2024 | 07:27 PM
JohnZo's Avatar
Connect the strap using the bracket bolt. The other end goes to the firewall.
ReignRock
Dec 29, 2023 12:50 PM
DefenderSISU
Jul 11, 2022 05:55 PM
N E WHR
May 3, 2021 06:20 PM
newpassion
Mar 2, 2014 12:57 PM
Disco Stew
Mar 30, 2013 12:43 AM
