Hidden winch mount
Old Dec 2, 2009 | 10:31 AM
oysterhead's Avatar
here it is, looks super burly to me: http://www.discovery2.co.uk/winch.html
Old Dec 2, 2009 | 02:54 PM
meltdowndave's Avatar
Originally Posted by Willie00d2
I have the Hidden Winch mount that I bought from Meltdowndave installed now. I put a Warn M8000 on it I had laying around. The control box is mounted in the old jack location. I also hooked up a in cab control switch with a safety switch and LED.
The front only sags a 1/4 more now with the winch. I will probably get some 2" heavy duty lift springs soon. I already have OME shocks installed.
Has anyone had any problems with the mount moving while under high loads? I have not used it yet under any load. Just wondering. I have the bolts very tight. I was considering adding some brackets or turn buckles from the winch base then up to the frame.
Willie
Glad you got it installed, Willie.
I never had an issue with it on the times that I tested it, but never put it under a full load.
I'd imagine the weak link, if there is one, would be the bolts. Perhaps something more heavy duty would put your mind at ease?
Old Dec 3, 2009 | 06:13 AM
Jull's Avatar
Has anyone installed one of those on a D1? Unlike the D2, there is an oil cooler in the way on the D1, which may cause the winch to sit pretty low.
Old Dec 3, 2009 | 10:27 AM
Urban Panzer's Avatar
The oil cooler on the D1 sits way higher than the winch, will not affect it at all, the D1 setup is almost identical
Old Dec 3, 2009 | 11:53 AM
yesmar's Avatar
it looks sooo clean
Old Dec 3, 2009 | 12:52 PM
How is it mounted and to what?
Old Dec 3, 2009 | 02:59 PM
oysterhead's Avatar
can you post pics?
Mike- look here! http://www.discovery2.co.uk/winch.html
Old Dec 3, 2009 | 06:44 PM
Willie00d2's Avatar
I don't know how to upload picture's onto the forum.
Willie
Old Dec 3, 2009 | 09:44 PM
Willie00d2's Avatar
Old Dec 3, 2009 | 11:44 PM
Willie00d2's Avatar
Thanks again Dave, I am happy with the mount. I am going to add a bracket made from 3 inch angle iron to the frame. I have a few picture here, I will post more soon.
http://www.flickr.com/photos/roverd2...7622805456131/
Willie
terryth
Sep 14, 2020 08:39 AM
Funtogun
Jan 5, 2015 05:45 PM
Disco Mike
Apr 16, 2012 10:38 AM
psykokid
Oct 30, 2011 09:45 PM
yloDiscoII
Jun 2, 2011 06:48 PM
