High idle after engine swap
Old Nov 11, 2008 | 08:01 AM
clanceyk's Avatar
Default High idle after engine swap
I need some help figuring out why my 98 Disco is idling at about 2000 rpms. It started after I had a slipped sleeve and had to replace the engine with an engine from a 96 Disco with about 90k miles on it. Everything else seems to run fine, just the truck is always lurching forward because of the high idle. Occasionally it will go back to normal, but then after starting it again a couple of times the problem comes right back. I took the TPS sensor out of the old engine to see if that would fix it, but no such luck. I have heard that perhaps the gasket on the TPS could be bad and causing the problem and I will be trying to swap that out today. Are there any other suggestions?
Old Nov 11, 2008 | 08:42 AM
Default RE: High idle after engine swap
Did you replace the short or long block, have you checked for a vacuum leak?
Old Nov 11, 2008 | 08:47 AM
clanceyk's Avatar
We used a long block, but the mechanic had to pull of the fuel injection system because it didn't match what was in the truck so the system from the old engine was used.Supposedly my mechanic checked for vacuum leaks. Where might I look for a leak?
wick_60010
Nov 22, 2017 04:25 AM
atancreti
May 26, 2015 05:23 PM
me 2
Jun 24, 2012 12:49 PM
dean52173
Dec 10, 2010 10:08 PM
leadfoot
Mar 19, 2010 09:09 AM
