Hmmm Sunlight Sensor gone bad?
Old Aug 9, 2019 | 01:18 PM
CollieRover's Avatar
As far as I can tell my cooling and A/C system is 100% I think it is just Land Rover being OK with temps we don't like.
Old Aug 9, 2019 | 01:25 PM
dparham's Avatar
yup lol. mine would just soar in temp until a/c would stop functioning as if high pressure side too high and compressor not turning off.. but then when covering this sunlight sensor it has tamed itself.. so im not sure what to think but until I know more Im going to cover it lol
Old Aug 9, 2019 | 02:11 PM
Llamasayswhat's Avatar
From Rave :
"Sunlight sensor The sunlight sensor consists of two diodes that provide the ATC ECU with inputs of light intensity, one as sensed coming from the left of the vehicle and one as sensed coming from the right. The inputs are used as a measure of the solar heating effect on vehicle occupants. The sensor is installed in the centre of the fascia upper surface."
and
"Solar heating correction is employed when air distribution is set to face level or to face and footwells. The correction progressively increases the blower speed, up to a maximum of 9 steps, with increasing values of solar heating"
The solar sensor is tied in with the ambient air temp sensor to ramp up AC fan speed to help compensate for the sun beating down on your dashboard.
It has no effect on engine cooling, unless you have other issues, i.e. over charged AC causing increased evaporator/condenser temps, poor condenser fans, poor condenser flow.
I'd recommend taking it to a competent euro shop and letting them service the AC system, check pressures, check charge, check fan operation and condenser condition.
Old Aug 9, 2019 | 09:33 PM
05TurboS2K's Avatar
Originally Posted by Llamasayswhat
From Rave :
and
Very good find sir.
Old Aug 11, 2019 | 01:53 PM
dparham's Avatar
I ran the diagnostics on the climate control module and I got no codes. however covering the sensor defiantly prevents my disco from running hot and a/c overloading so there just must still be some issue in system.. I did put a used compressor on years ago so maybe its just not performing properly.. ironically it does work nice with sunlight sensor covered... its been long enough ive got my money out of the used compressor so I guess its time to let an a/c specialist take a crack at it again... the replacement compressor has worked but never was great... also I dont think IM hearing my compressor go off... been super busy last couple years so haven't had a chance to take car out of commission... maybe ill get a spare lol
Old Aug 11, 2019 | 08:34 PM
Ben Matheson's Avatar
Yeah as I stated earlier covering the sensor just reduces ac load. You could accomplish the same thing by setting the AC a couple degrees higher
Old Aug 11, 2019 | 08:56 PM
dparham's Avatar
well ironically I tried that but it didnt help....
Ben Matheson
Oct 13, 2018 06:02 PM
MrWesson
Apr 14, 2016 10:22 PM
LR3BB
Oct 28, 2015 04:13 PM
uoflcardfan77
Aug 25, 2015 03:09 PM
Bishop
34
Oct 29, 2014 01:27 PM
