Hood Release Failed
Old Oct 16, 2016 | 12:22 PM
huggi's Avatar
Default Hood Release Failed
I know this has been posted before, any solution besides breaking the grill or headlight. My hood has been very hard to shut, had to slam it with all my weight about ten times before it would catch (meaning would stay down all the way), while doing this I could still reach under and pull the yellow latch to open the hood. Now that doesn't work either.
Was wondering, had my windshield replaced by safelite 2 days prior, do you think they might have done something (do they even have to open the hood to change the windshield?).
Any help would be appreciated, thanks.
Old Oct 16, 2016 | 07:42 PM
Externet's Avatar
Try someone sitting on the hood front and pulling the releaser, praying the cable will not break.
Before getting into trouble, I did this. It may help :
----> https://landroverforums.com/forum/di...aranoia-60156/
Old Oct 17, 2016 | 03:41 AM
batard's Avatar
It could easily be related to the windshield change. They had to remove the hood to remove the lower cowl and replace the windshield, and they probably got the alignment slightly off when reattaching it.
Old Oct 17, 2016 | 02:10 PM
huggi's Avatar
I think thats exactly what happened. I sprayed a bunch of wd40 in there, was able to lock the hood by slamming it down. I realized the hood release was working (nothing broken), the frame that hold the hook thing was off, or the hood relative to the frame. I pulled the hood up pretty hard while pushing the yellow tab and it opened. I moved the hood latch frame thing backward (relative to the car), and it works great. Also the WD40 helped a lot with the difficulty closing the hood.
What kind of grease can I use on the spring part, I know WD40 isn't that great.
Old Oct 17, 2016 | 02:21 PM
batard's Avatar
White lithium grease is good for hinges and such, where you want to have a coating of grease that sticks around.
Old Oct 18, 2016 | 04:38 AM
OffroadFrance's Avatar
This type of cable oiler might also help as well.
I used to use an old bicycle inner tube (6" length plus inflation valve at one end) clamped on the cable with electrical tie wraps then filled with a small amount of oil and then sealed and pressurised with a cycle pump. It worked like a dream on my motorbike brake and clutch cables. These days they are Teflon coated.
Old Oct 18, 2016 | 04:44 AM
Cable Oiler | eBay
Old Oct 18, 2016 | 04:20 PM
Externet's Avatar
Murphy's law says...
When you finish oiling the actuator cable in its jacket, you will find what binds is the latch pivot.
That is what cured mine, oiling the release mechanism under the hood.
Old Oct 18, 2016 | 05:14 PM
Charlie_V's Avatar
When I had my windshield replaced the shop removed my hood, so I'm sure that's what happened to yours.
They didn't put the hood in the same spot when they tightened the four hood bolts--same as yours.
Old Oct 19, 2016 | 07:01 AM
mln01's Avatar
Sounds to me more like misalignment of the bonnet than a lube issue. But you can't address either if you can't get the damn thing open. For that I have no secret sauce to offer. I wish I did.
steveo2000
Sep 8, 2015 08:00 AM
jerkshirts2
Jan 2, 2009 11:40 AM
rjmaype
Jan 18, 2008 08:00 PM
Doak
Jan 12, 2007 11:07 AM
kram2179
May 16, 2005 12:34 AM
