Hood won't close
Old Sep 1, 2018 | 05:17 PM
Aj6543's Avatar
Default Hood won't close
I was working on my car, and when I try closing the hood, it won't shut completely. What happened?
Old Sep 1, 2018 | 05:26 PM
CollieRover's Avatar
Try greasing the mechanism where the hood mates to the body.
Old Sep 1, 2018 | 09:00 PM
Aj6543's Avatar
That worked! Thanks CollieRover!
Old Sep 1, 2018 | 09:45 PM
You’re Welcome. It happened to me years ago after removing the hood, and I adjusted and adjusted, no affect, greased it, hasn’t done it since.
Old Sep 2, 2018 | 05:03 AM
OffroadFrance's Avatar
Hi, if you use motorcycle chain lubricant once a year it never seizes up but also be aware the operating cable can also seize or break.
Old Sep 2, 2018 | 06:44 AM
The loop that connects my cable to the bracket has stretched and I had to twist a little piece of wire in there to reduce play. I should check on that.......
Carlos Man
Sep 18, 2019 10:13 AM
bearskinrug
Jun 13, 2014 06:45 PM
wesley64
May 28, 2013 06:46 AM
evoking
Dec 23, 2011 08:11 PM
jw928
Sep 23, 2010 04:24 PM
