Horn beep when locking/unlocking?
I don't think so. I've never seen any options for making the horn beep when locking the doors, and I don't see it in RAVE. I could be wrong... if you find the option, let me know what it's called and I'll test it on mine.
So.... attach a relay to same connection as lock motors, and it should energize for the pulse of the lock motor. Wire contacts to horn. It would be the pink/red wire and pink/purple wire. Pink and gray are superlock. IMHO while in there you may as well snip that rascal, so you can prevent superlock from engaging. Now if you include a diode in series with relay coil, you can make it energize only on lock or only on unlock, polarity is reversed to make lock motor run other direction. Don't forget to use fuses.
Might be a longer horn beep than you like, there are relay/timer boards that can provide a short duration output.
Something to consider if you have close by neighbors.
I HATE cars that honk at me when their owners lock or unlock the doors. But what I've really come to hate is the newer GM vehicles that turn on the reverse lights when they unlock the doors. I never know if a car in the parking lot is trying to back out or not. My new rule is to never be polite to GM owners. They can back out after I'm done driving past them.
