Hose clamp options
Old Nov 11, 2010 | 08:31 PM
Fireman's Avatar
Does that key come out or does it permanently stick out like some sort of phallus?
Old Nov 11, 2010 | 08:56 PM
mwindth's Avatar
Originally Posted by jlighthall
Ummm, jlighthall...did you actually read the Wikipedia link you supplied? I'm not saying Wikipedia is always right (either is Google for that matter), but it directly contradicts what you wrote.
First paragraph, second sentence from the link you supplied: "Stainless steel does not stain, corrode, or rust as easily as ordinary steel, but it is not stain-proof."
Second paragraph, forth sentence from the link you supplied: "Stainless steels contain sufficient chromium to form a passive film of chromium oxide, which prevents further surface corrosion and blocks corrosion from spreading into the metal's internal structure.
I would re-think your sales pitch
Old Nov 12, 2010 | 09:08 AM
jlighthall's Avatar
6th Gear
Originally Posted by Spike555
Whats the melting point of this flexi clamp?
The Flexi-Clamp has been tested to best operate in a temperature range between -50 F and 300 F .
Old Nov 12, 2010 | 09:14 AM
jlighthall's Avatar
6th Gear
Yes, the key comes out. In fact you don't need the key at all. A lot of electricians use these to bundle wires because if they need to add an additional wire later, it is easy to take these apart with a cordless drill and a socket.
Old Nov 12, 2010 | 09:37 AM
jlighthall's Avatar
6th Gear
Hi mwindth,
Thanks for helping me make that correction. What should be said is that stainless steel is neither 100% stain or rust proof, but the Flexi-Clamp is
Old Nov 12, 2010 | 08:34 PM
So they wont work on or near the exhaust.
Old Nov 13, 2010 | 08:52 AM
jlighthall's Avatar
6th Gear
Currently the manufacturer has only tested the Flexi-Clamp to 300F. I have sold/installed their other products for almost 20 years and they are always very conservative with their testing numbers.
robert.juric
Jun 22, 2015 01:43 PM
cer308
May 20, 2012 12:29 PM
outdoor7or24
Apr 1, 2012 09:01 PM
JB99Disco
Feb 18, 2011 09:38 AM
starcraft
May 11, 2009 02:20 PM
