How to activate SLS without engine installed
Old Dec 26, 2013 | 08:04 AM
BCDisco2Lando's Avatar
Default How to activate SLS without engine installed
First off Merry Christmas to you all,
I am looking for a way to activate the SLS on our 1999 D2 so I can raise the rear of the truck again. As I have been working on our truck for some months now the airbags have slowly leaked and the rear is quite squatted. I need to do some exhaust and drive shaft work but have not installed our new engine yet so no signal from there and the SLABS needs that signal.
I tried connecting 12V directly to the SLS compressor and it clicks but no pumping, so the conclusion I came to there was the solenoid valves don't open with out a signal from the SLABS.
Has anyone been succesful turning on the compressor without an engine or found a way around this.
Thanks
Old Dec 26, 2013 | 08:31 AM
Oooppsss...
Too much turkey I think...
I realized I had connected the 12V power to the exhaust valve electrical connector instead which would explain no pump turning on, but would still like to know if this idea will still work.
Thanks
Old Dec 27, 2013 | 06:25 AM
drowssap's Avatar
you could try putting power to the control unit while pushing the Raise button inside on the dash.
hriant88
Nov 9, 2014 07:05 PM
jmirandes
LR4
Nov 5, 2012 03:50 PM
jungle truck
Mar 17, 2011 03:29 PM
DiscoIIBrandon
Dec 2, 2010 02:42 PM
Disco Den
Feb 1, 2010 11:32 PM
