How bad is the wear on this crankshaft pulley?
Old Jul 23, 2021 | 07:47 AM
XRAD's Avatar
take the dampener to a machine shop and have it micropolished in opposite direction of rotation....
Old Jul 23, 2021 | 09:27 AM
dswilly's Avatar
In case a Speedisleev is needed. Install was easy. Part number
SKF 99192
Old Jul 23, 2021 | 10:04 AM
Brandon318's Avatar
I’m going to go forward without the speed sleeve first, and if it leaks again, it’s not an issue to pop out the HB later and try that fix.
That being said, do I need a different size front seal if I use the sleeve? Or is it just same same?
Old Jul 23, 2021 | 11:50 AM
dswilly's Avatar
Same seal will work. The sleeve is engineered to not add much to the shaft diameter.
Old Jul 23, 2021 | 02:53 PM
Brandon318's Avatar
Is there a way to prevent this sort of thing from happening? Or are these pulleys just considered consumable?
Old Jul 23, 2021 | 03:22 PM
The Deputy's Avatar
Changing oil at recommended intervals helps, as debris get impacted on backside of seal and causes wear...or replacing the seal before it gets extremely brittle.
Old Jul 24, 2021 | 09:05 AM
gulfstream69xr7's Avatar
What does the rubber seal on the pulley seal to?
I've never removed the balancer.
Old Jul 24, 2021 | 10:41 AM
nashvegas's Avatar
Few thoughts:
1) Yes, these pulleys are considered consumable eventually
2) I wouldn't agree that the cracked rubber is no big deal... I guess you have never had one come apart! When that rubber fails, the outer ring of the pulley separates from the inner. That rubber is manufactured into the pulley which is press fit together, if the rubber fails, the pulley comes apart quite dramatically. If you're lucky, it just spins on itself. In my case on an old 03, it took out my radiator, fan, pulley, fan shroud... on a drive through Alabama a few years ago. Hence why I see those cracks and replace the pulley. Classic failure mode of these crankshaft pulleys.
3) I've reused pulley with visible marks on the shaft, but if you can feel the wear with fingernail etc, yes replace it.
Old Jul 25, 2021 | 12:56 PM
Brandon318's Avatar
After waffling back and forth, went ahead and ordered a sleevy thing. Even if it grants me another year or two - I'm in the middle of building a house and just need this old boye back on the road. $700 needs to go toward a houseful of 12/2 romex right now, not a new HB.
Also, when I eventually order a new one, how do I go about doing so? Can't be as simple as putting one in my Atlantic British cart is it? With the different weights and all?
thehulk
LR4
Jan 30, 2020 08:45 PM
chgan
Nov 19, 2017 11:09 PM
Oasisplayer311
Jan 17, 2017 03:42 PM
jbkroh
Oct 19, 2012 09:40 AM
73S3IP
Aug 10, 2009 08:46 AM
