How to change the trans fluid on a DII
Old Nov 15, 2010 | 09:08 PM
  #51
Fireman's Avatar
Holy crap EOD2135, I think your filter was dirtier than mine and that is hard to do! Was your old filter black or was that silt?
Old Nov 21, 2010 | 10:59 AM
  #52
jpluncford21's Avatar
Originally Posted by DiscoveryHouston
oysterhead, once you pull the drain plug and let it drain for 5 minutes or so you good to pull the pan. Unscrew the 6 screws holding the pan and you good. Now once you move the pan out of the way, your going to have residual fluid bubble along the veins of the transmission and what not. I just got a lint free cloth and dabbed the area lightly so that I wouldnt get a nice drip in the eye lid. When you remove the filter its going to have alittle inside it, but nothing like the pan holds. I promise you its a simple operation.
Hey I'm about to do this today when I get home. I've got the gasket and filter for my 04. Wanted to check, do I need any "glue" for the gasket like what I would need for the diffs? And do I need a "special" tool to get the filter off? I've read the name of it, but I'm in a hurry at the moment and about to head out the door so can't search for it. Thanks for the help
Joseph
Old Nov 21, 2010 | 04:17 PM
  #53
Fireman's Avatar
No, no glue. Make sure you have a new gasket and torque the bolts to 8 Nm. I swapped mine to 6Mx1.0 SS allen-heads to avoid corrosion. You may want to put some anti-seize on the threads too.
Old Nov 21, 2010 | 04:19 PM
  #54
Fireman's Avatar
BTW, you will need a torx screw driver or bit to remove the filter.
Old Nov 23, 2010 | 05:04 AM
  #55
elrocha69's Avatar
Originally Posted by Baylink
So here's the thing...
My drain plug appears to have the head (and hex socket) ground down flat on it, somehow. Is this the plug that everyond kvetches about it being plastic, and AB sells a brass replacement? If so, what's the recommended way to get it out, since I can't wrench it.
I assume I don't want to drill it out; metal filings in your AT aren't really recommended...
get a hammer and chisel and hit the drain plug on the edge to make it turn counter clockwise. That will get it loose and you can replace it.
Old Dec 19, 2010 | 11:25 AM
  #56
texmbr's Avatar
The Autozone filter kit number is TF186. Includes gasket and o ring. 15 bucks out the door.
Old Dec 19, 2010 | 01:38 PM
  #57
texmbr's Avatar
Wanted to correct this. The correct Autozone Tran Kit is TF184. Sorry.
Old Dec 21, 2010 | 07:16 AM
  #58
jbarr89's Avatar
TF184 is the one for a 04 also?
Old Jan 7, 2011 | 10:40 AM
  #59
wrp's Avatar
wrp
I broke off one of the 7/16" hex bolts that holds up the transmission pan. The other bolts seem like they'd be ready to also break if I apply too much torque to unscrew them. I suppose I could drill out and tap new threads but that's not my favorite thing to do on my back. Any other suggestions? Thanks.
Old Jan 10, 2011 | 07:38 AM
  #60
Fireman's Avatar
Where did the bolt snap? The same this happened to me, but when mine snapped, just the head came off. I was able to get a stud extractor on what remained and it backed reight out. Can you take a pic?
