how to clear the 3 amigos ?
I have the 3 amigos, I replace front rotors and pads, cleaned ABS on both wheel. replaced the brake fluid. (i'm still going to change the rear calipers seal as I received by mistake the kit for the rear instead of the front) now I just went to Autozone to see if the could read the code and clear it. they told me to go to the dealer...... is there anyway I can clear this myself ?
RE: how to clear the 3 amigos ?
Before you try to clear the faults, you might want to see what they are and what may be causing them. Quite often it is just a momentary glitch and sometimes it is more major. Find a shop that has a lap top type scanner, not a hand held engine scanner, something like an Auto Logic or similiar scanner and see what is going on, then see if the shop will clear the faults, after writing them down. If the lights stay off you are set, if you get the same code again, you'll know it is time for a repair.
cammyr01
01-05-2015 02:42 AM
