how to clear the 3 amigos ?
Old Nov 4, 2007 | 03:35 PM
loic's Avatar
Default how to clear the 3 amigos ?
I have the 3 amigos, I replace front rotors and pads, cleaned ABS on both wheel. replaced the brake fluid. (i'm still going to change the rear calipers seal as I received by mistake the kit for the rear instead of the front) now I just went to Autozone to see if the could read the code and clear it. they told me to go to the dealer...... is there anyway I can clear this myself ?
Old Nov 4, 2007 | 04:36 PM
Default RE: how to clear the 3 amigos ?
Before you try to clear the faults, you might want to see what they are and what may be causing them. Quite often it is just a momentary glitch and sometimes it is more major. Find a shop that has a lap top type scanner, not a hand held engine scanner, something like an Auto Logic or similiar scanner and see what is going on, then see if the shop will clear the faults, after writing them down. If the lights stay off you are set, if you get the same code again, you'll know it is time for a repair.
Old Nov 4, 2007 | 06:45 PM
loic's Avatar
ok, I just posted in a Las vegas forum, where I could find a place that will read the faults. I hope somebody will answer, I can't afford to bring it to LR shop...
Old Nov 4, 2007 | 07:13 PM
If you are in the Las Vegas area, get in touch with their local Rover club and they should be able to help.
cammyr01
Jan 5, 2015 02:42 AM
iplayblues4u@comcast.net
Jan 6, 2010 08:43 AM
VikingDiesel
Jun 10, 2009 09:06 AM
VikingDiesel
May 25, 2009 10:24 AM
Darksidetone
Feb 9, 2007 09:15 PM
