How to diagnose alternator failed component ?
Old Feb 18, 2024 | 12:53 PM
Externet's Avatar
Question How to diagnose alternator failed component ?
Hello
Recharged battery, shows 12.6V. Starts well, idles well, and after ~10 minutes all dies with not enough voltage for cranking, measured voltage is ~9 V.
Put another battery, same story. Measured voltage while engine running : never reaches 13.8V nor above 12.6V = Alternator not charging.
How to find if failure is brushes, internal regulator, rectifiers, stator, rotor, open connection or else ? Inside fuse 24 tested OK. Belt is taut. Electrical system of all vehicle is unmolested original that never gives trouble.
Old Feb 18, 2024 | 01:35 PM
Externet's Avatar
Question
Brown wire has to be the output of the alternator as goes to a 150 Ampere link, but it is not connected to the cathodes in the alternator (?)
White wire to the alternator appears to be the 'enable' connection for the alternator to work, Is it ?
Is the brown/yellow wire to indicate 'not charging' light on the dash; is that right ?
Correct me, please.
Old Feb 18, 2024 | 02:13 PM
Extinct's Avatar
Disassemble and look at brushes, I did a thread on it in last two years. Search on keyword alternator and me as thread originator.
Old Feb 18, 2024 | 10:24 PM
JohnZo's Avatar
If it is like the D1 system, if the light bulb (J100 on diagram) is bad, the alternator won't charge. Weird, I know. I keep a spare in my trail parts bag.
jahummer
LR4
Apr 23, 2024 11:35 AM
bcurtman
Mar 26, 2019 08:05 PM
Twix
Apr 8, 2017 04:32 AM
EastCoast
May 24, 2016 10:56 AM
trospierski
Jun 19, 2012 06:53 PM
