How did Doug at AB remove the fan without a fan clutch tool?
Old Apr 20, 2023 | 03:28 PM
disco_nap's Avatar
Default How did Doug at AB remove the fan without a fan clutch tool?
I'm trying to replace my water pump, but I'm stuck at the getting the fan off step. In this video from AB, Doug gets it loose with a wrench and a rubber mallet -- both of which I've got -- no fan clutch tool:
This other video tells me I need to use a fan clutch tool (which I don't have):
Is Doug working sorcery???
Should I just suck it up, pay $50 for this:
Amazon Amazon
and return the fan wrench I bought?
Old Apr 20, 2023 | 03:31 PM
V50-M66's Avatar
If it hasn't been off in a while, it gets quite tight. You need a 36mm fan wrench and a mallet, and just beat the crap out of it. I've found that a wooden mallet (like for woodworking) works great, since you can get some good speed going on it and it transfers energy much better than rubber.
Old Apr 20, 2023 | 03:33 PM
disco_nap's Avatar
Oh, the problem isn't that it's tight. I got the wrench in place fine, it's just spinning freely.
Old Apr 20, 2023 | 03:59 PM
disco_nap's Avatar
AHA!
I found this other video on AB -- looks like a long screwdriver should do the trick for me w/o having to buy the special tool:
https://www.roverparts.com/resources...e-discovery-2/
Edit: Yep, long screwdriver was all it needed. Fan is off.
Old Apr 20, 2023 | 04:12 PM
V50-M66's Avatar
Ah gotcha. Screwdriver works - I have a nice long one from Harbor Freight that works great. Also, in case you aren't doing it this way, it helps bigtime to do it with the belt still on the engine to help keep the water pump from moving
Old Apr 20, 2023 | 04:13 PM
disco_nap's Avatar
Yep, the (lack of) belt was part of the problem -- looooong story, but I had to snip it with a pair of shears. Thanks for the advice though -- It did take a couple strong whacks in addition to the extra leverage
SurfinTillTheEnd
Feb 17, 2022 11:09 AM
GunnerandDeena
May 31, 2017 04:31 PM
Spike555
Jul 21, 2016 08:07 AM
apcollin
Dec 8, 2009 08:45 PM
1stshift
May 5, 2009 04:11 PM
