How to disable ABS?
Old Nov 14, 2006 | 01:34 PM
storz's Avatar
Default How to disable ABS?
Is anyone have an idea, how and where to fix switch for disable ABS system. A few months ago (maybe Year) I read on forum disco2.com, but this forum not exist any more. I think, that you need to separated a wire with switch, but I not remeber where they are.
Old Nov 14, 2006 | 02:41 PM
Default RE: How to disable ABS?
What year is your truck and why do you want to disable it?
Mike
Old Nov 15, 2006 | 04:47 AM
storz's Avatar
Year 03/2001. Why to disable? When you try to stop the truck in bad weather condition (snow,muld..) it's like in movie. If you unersand me, I'd like to disable only ABS, no TC or other controls.
Old Nov 15, 2006 | 10:19 AM
That will be a hugh mistake on your part. If you think the truck stop poorily now with the ABS you should see one stopping with out ABS. As for the T/C, without it, you might as well be driving a limo with one wheel drive.
I would bet your dissatisfaction is coming from bad tires and possibly a lack of experience driving the Disco or driving in poor weather. By the way, you can only turn off the ABS for short periods of time if you have CDL and know how to engage it so the ABS goes off.
Mike
Old Nov 16, 2006 | 06:28 PM
mikemeyer0's Avatar
I just pull my fuse when I go wheeling, Nothing like going down a steep sandy slope and the abs kicks in. Scares the crap outta you.
Old Nov 16, 2006 | 11:10 PM
meyersd's Avatar
ORIGINAL: storz
You need to get those baloney skin tires off your truck and get some real tires. Then your ABS will be a non- issue.
Old Nov 17, 2006 | 11:46 AM
ORIGINAL: storz
Also forgot to mention that the traction control is run by the ABS so if you want T/C you have to have the ABS engaged.
Think seriously about better tires.
Mike
Patrick Duffy
Nov 15, 2012 09:03 AM
harold.lloyd
Feb 24, 2012 09:12 AM
s10lowrider1994
Jan 16, 2012 07:08 AM
crownaviation
Sep 7, 2007 02:37 PM
oberdahill
Sep 14, 2005 02:28 AM
