how to disconnect auto leveling warning system?
Old Aug 1, 2007 | 09:54 AM
chadbormann's Avatar
Default how to disconnect auto leveling warning system?
i had the air pump go out, so i disconnected the lines from the pump and rigged up a manula system whereby i can fill the bags with any old airpump. the prblem is, the autoleveing malfunction light is now on, and the dinger rings constantly. i would take out the fuse, but on a 2000, the fuse also runs the anti lock breaks. ayone know whih line to sip or what you ca do to disconnect the auto leveling waring dinger?
Old Aug 1, 2007 | 11:04 AM
okdiscoguy's Avatar
Default RE: how to disconnect auto leveling warning system?
Have to use Testbook or Autologic scanner to re-program slabs ecu not to read the air suspension.
Old Aug 1, 2007 | 12:38 PM
so there's nothing you can cut to stop the dinging? my closest dealer is 2+ hours away and i think i'll go crazy driving it that far to be reprogrammed.
edit: solution, if you plug the compressor back in but leave the lines unplugged, it fixes it. great solution. with under $5.00 invested, i have a new air system!
Old Aug 1, 2007 | 03:28 PM
dow's Avatar
dow
follow the ding, find the buzzer, cut wire
Old Aug 1, 2007 | 04:06 PM
Landzu's Avatar
Check Atlantic British I thing they have a bypass when you go with springs.
Old Aug 1, 2007 | 05:51 PM
okdiscoguy's Avatar
ORIGINAL: Landzu
They do. I don't think they sell it anymore by its'self. Everything I have found to bypass is more than a new compressor....
chadbormann: do you have any indy rover shops by you? You can call Atlantic british and they will locate the closest place that has an autologic scanner...
girouardrover
May 11, 2015 06:26 AM
Greatpyr
Jun 19, 2013 05:22 PM
R anger over
Mar 19, 2013 02:58 PM
PabloM
Sep 17, 2012 02:45 PM
sorbet35
Feb 27, 2012 07:31 PM
