How do I activate heated seats?
Old Oct 24, 2019 | 11:12 PM
Carlos Man's Avatar
Default How do I activate heated seats?
Just ordered this part on eBay to replace my non-heated seat option lay out... does anyone have a how to on activating the seats, and will I need any extra parts?
2004 LRD2 SE7 All Leather
Old Oct 24, 2019 | 11:52 PM
Brandon318's Avatar
When you remove the existing switch panel to install the new one, you'll see two green plugs that aren't plugged into anything. Those are your heated seat switch plugs. Look under the seat next and you'll see a...yellow(?)...plug that's similarly not plugged into anything. It should be obvious when you look under there. I did this with my 2002. Fifteen minutes of fussing around, and what was once a several hundred dollar option almost two decades ago, was nearly free to enjoy.
Old Oct 25, 2019 | 01:09 AM
Discorama's Avatar
Can confirm. It's plug and play.
I also added two motors (used ebay) on the pass seat and now it is height adjustable. I guess it was an expensive option then too. Lumbar support can be added on the pass seat too. The switch works and wiring is there.
Old Oct 25, 2019 | 01:10 AM
Brandon318's Avatar
Ahhh... I was wondering if that height adjustment was retrofittable. How was the motor install?
Old Oct 25, 2019 | 02:17 AM
JUKE179r's Avatar
I've understood you need leather seats to have the seat heating option.
My SE has leather seats but didn't have the seat heat switches. I bought the center switch panel with the seat heater switches and it was plug and play. Still works great.
Old Oct 25, 2019 | 06:20 AM
AussieRover111's Avatar
If you have leather you can buy this?.. plug it in ?
Do all the Disco II's with leather have seat heaters?
Is this a fire issue?
Old Oct 25, 2019 | 06:23 AM
Carlos Man's Avatar
I see only one green and one black plug that are both loose and waiting to be conducted. I don’t see another green one.
also this yellow plug that’s not plugged to anything ... did you plug it into something?
Old Oct 25, 2019 | 10:25 AM
Dave03S's Avatar
My truck came with heated seats and no leather, so you would be wrong. S model with cold weather package... Heated seats and windscreen.
Old Oct 25, 2019 | 11:04 AM
Carlos Man's Avatar
this is what I’m looking at
Old Oct 25, 2019 | 11:39 AM
Best4x4's Avatar
Heated Seat relay is black, wiring connector is color coded per side & the switches are keyed for passenger/driver. Normally all leather seats = came with heated elements from the factory as it saved the production line from having two lines. Switches are usually all that are needed.
