How do I bleed ACE System?!?
Old Nov 7, 2007 | 11:22 AM
SICSOLX's Avatar
4wd High
Default How do I bleed ACE System?!?
Currently rehabing a 2000 Disco II w/ 185000 miles. My ace pump is making some noise and the distribution block on the right side of the vehicle (under the pass. front door next to frame rail) is making a hissing noise, similar to bleeding off air, every once and a while. Not sure if this noise is normal.
Point being, I would like to bleed out the old fluid from the system. I purchased the Tech book from Atlantic British and it states that test book must be used to do this. Is there a way that I could bleed the system on my own without computer assistance. Also, I see that there is a filter that goes into the distribution block. I am assuming that this should be changed? Any info or suggestions would be appreciated.
Old Nov 7, 2007 | 12:01 PM
Default RE: How do I bleed ACE System?!?
Don't even attempt to drain the system, you will be looking a BIG $$$'s. Call me this afternoon, after 2PM and before * pm Colorado time and I'll walk you thru an easy way to handle the problem.
303-862-7680
Colorado
Tin_Man
Apr 12, 2014 11:12 AM
captain203
Dec 15, 2013 05:01 PM
JavaDiscoII
May 29, 2010 04:33 PM
tbuckt007
Apr 13, 2010 11:46 AM
alrd
Nov 17, 2006 11:25 AM
