How do I clean my throttle body and it’s hoses?
Old Mar 7, 2020 | 06:18 PM
Best4x4's Avatar
Passenger side hose which the plastic nipple on the intake attaches to = follow it down to the valve cover. I describe it step by step in the sticky.
Old Mar 7, 2020 | 06:39 PM
OverRover's Avatar
> https://www.roversnorth.com/category...i_rocker_cover
Old Mar 7, 2020 | 07:42 PM
Carlos Man's Avatar
that really helps, thank you so much.
Old Mar 17, 2020 | 08:53 PM
Carlos Man's Avatar
Okay so I removed the oil separator (had to drill it out in pieces) it’s hollow and clean now.
so next step is to increase the size of the hole correct?
also received the pvc
Old Mar 17, 2020 | 10:50 PM
Best4x4's Avatar
thread the PCV into the intake (replaces plastic black nipple), then once the tube is drilled out where the plastic baffle lived re-install the hose and bingo all done.
Old Mar 20, 2020 | 08:17 PM
Carlos Man's Avatar
Default Done Problem solved!
Removed my IM and installed new coil packs, ignition wires, IM gasket, and air filter....
also did the PCV mod ....
she’s running strong.
I just used that bit and held the sleeve with pliers.... had to let it cool about 4 times before I was done... mod takes less than 10mins
Hammered this guy back in softly
POS wires and two different brand coil packs
Magnecore 8s From AB with L8’s coil packs
whowa004
144
Sep 3, 2024 11:02 PM
dmannrover
Jul 31, 2019 11:57 AM
EricTyrrell
Sep 27, 2014 02:23 PM
RoverLover21
Nov 21, 2009 02:41 PM
