How do i pop the hood when the cable is broken?
If your cable has snapped where the latch is under the bonnet then it is difficult but do able.
The is a plastic shroud covering the mechanism, you can see this when looking through the front grill. You need to cut this away with a SHARP knife, Stanley knife or something.
This is easier said than done! It's tough plastic and getting to it is a pain in the ......
Once achieved, push a piece of wire through to the hook part of the latch and having made a loop at the end of the wire catch the hook with loop and pull hard!
Took me a few try's but got it done. Fixing a new cable is the easy part.
Cheers Jerry
Cheers Jerry
I ended up drilling the front rivet out with my drill. Then popped the plastic ones with a hammer and screw driver. Then I had to figure out how the mechanism worked to know what to pull on. I had to hook the handle of a wire fly swatter to the metal the spring was attached to and pull really hard. I did all this in the dark while holding a flashlight in my mouth. It was a pain in the *** but I got it to work.my next step is to mount a bicycle brake handle right behind the grill and attach the cable. That way all I have to do is reach in and push the lever down.
I just did this about 45 min ago. I took a small thin crow bar, but you could use a large flat head screw driver. If you can't pull the cable, with vise grips from the cab and all hope is lost, you can use the flat side of the crow bar / flat head screwdriver and with two good whacks from a hammer on the edge of the plastic latch cover you can break it open slightly to then push the release pin and release the hood latch.
Anyone that tells you to pull your headlight out or break your grill is nuts. That lower latch cover has got to be much cheaper than the grill or potential broken headlight.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
