How do I remove the rear speed sensor?
Old May 10, 2012 | 11:19 PM
Draayer's Avatar
Default How do I remove the rear speed sensor?
How do I remove and replace the rear speed sensor in a 2001?
Thanks
Old May 11, 2012 | 02:02 AM
elrocha69's Avatar
Remo er the caliper, caliper bracket and rotor. Spray some pb blaster or rust penetrant for the brake rotor set screw. Once you get that off, you will be able to remove the sensor with an allen wrench/ hex head socket bit.
Old May 11, 2012 | 10:14 AM
Why are you removing it, do you have a fault code number, if so what is it?
Old May 13, 2012 | 03:43 PM
Draayer's Avatar
Default This is the code I have
Disco Mike
1.--Current Faults---->
Active Faults:
067:Rear Right sensor electric fail
Logged Faults:
<-END Faults
Redd
Mar 12, 2014 10:03 AM
wheelgarage
Oct 1, 2011 03:12 PM
twaszak
Jun 4, 2011 07:49 AM
vandal996
Feb 17, 2011 09:44 AM
caleb
Jan 6, 2010 11:26 AM
