How to remove speed sensor
1999 Disco II, I can see sensor, I just want to get speedometer working so my son don't get a ticket. Is there a retaining clip,screw or anything? After unplugging how do I get it out? Also any one have a part#?
Thank you
Redd
Thank you
Redd
If I was driving it that would not be a problem, as My 17 yr son drives it and I would just assume to try to fix it correctly, not put a band aid on a problem. If it's 40 buck fine. I have came to this forum for correct direction and not zip tie and wire fixes. In all do respect sir. Dealers I am sure. We all agree are last resort. This website has been spoken highly as I was referred to. Thanks tho!
With all do respect Redd it was all in good humor. Download a copy of the Rave which can be found at www.centexrover.com/Disco/D2_Workshop_Manual.pdf
It is the Workshop manual for the Discovery 2. Also to locate part numbers I suggest you go to lrparts.ru/engl/ it is the Microcat parts catalog.
Just to be clear which sensor are you talking about? The wheel speed sensors are just bolted on i thing with an allen screw. Take a look at this thread.
https://landroverforums.com/forum/di...working-58937/
That's why I already posted about speedometer not working...I did get a scan and it scanned p0500 VSS so looked in manual as I stated in other post. On page 44-3 pointed out # 4 it say speed sensor. It is on left side of auto trans next to shifter...black in color and from what I can find I see wheel speed sensors. Aren't they for ABS? I am simply looking to get speedo working again. It just quit after 2 years. Is it possible that all wheel sensors were bad except 1 the when that went I lost speedo? Or is it the one on the side of trans as book states. Would that make speedo not work? Thanks guy!
So confused.. I was under the impression that D2s didn't have a VSS on the transmission. Speed is read off of the 4 sensors in the hub that see the notches on the CV.
Oh well...I will have to look into Rave on Monday.
