How do I test a Front Fog Light Switch
2003 D2. Purchased the truck 1 month ago with the front fog lights not working. The bulbs look good. When I push the switch on the dash, there's no indicator light (like there is on the rear fog light which work fine). The fuse is good. Connection is good on the back of the switch. Is there a way to bypass the switch with a jumper wire?
First, check fuse F3 (15A) in the engine compartment fuse box.
If that's OK, check the relay R12, also in the engine comapartment fuse box.
The front fog lamps switch switches a signal wire from the Body Control Unit (BCU) on switch pin 1, to earth on switch pin 4.
This momentary signal to earth, instructs the BCU to switch on the front fog lamps relay - but, only if certain other conditions are met.
Using an appropriate diagnostic tool, the BCU is programmable with the following front fog lamps options -
- The vehicle is not fitted with front fog lamps
- The front fog lamps will operate if the headlamps are on main beam
- The front fog lamps will not operate if the headlamps are on main beam
See - https://landroverforums.com/forum/di...43/#post455522
Last edited by PaulMc; 05-04-2015 at 08:33 AM. Reason: Added link to previous post
Apart from switching them off completely, the only BCU adjustment is whether they will stay illuminated, or switch off with main-beam.
They will always require side-lights or dipped-beam to be on, before the BCU will switch them on.
There's no way around that - unless, you change the switch for a latching type, and wire the BCU out of the circuit.
