How do you clean the radiator
You want to clean the outside or inside
outside is easy go from the front take a hose and wash it out
inside put a good rad flush drive it for 10-20 min take lower hose out let it drain take upper hose out take that hose again and flush it
you can flush everything just take hoses out
what coolant are you running????
They make cleaning products for radiator coils that foam to loosing up buildup. Then you simple spray out with a hose after the foam sits for a bit. May take a couple of applications if your radiator is real dirty,
aarongregor
Apr 22, 2012 02:28 PM
