How do you remove 2000 land rover discovery 2 ram bar/bumper guard
Old May 11, 2020 | 01:31 PM
Silverdiscoveryguy's Avatar
4th Gear
Default How do you remove 2000 land rover discovery 2 ram bar/bumper guard
Hello My name is joe i just wanna ask if anyone knows how to remove the stock ram bar or bumper guard its paint is chipping off and rusting so i wanna sand it and paint it does any one have some type of instructions or video
To take it off thanks?
Model:2000 Land rover discovery series 2
Old May 12, 2020 | 08:43 AM
boston4's Avatar
Depending on how old your truck is and your location, the hardware might be welded together with rust. If it were me, I'd probably just throw a sheet over the hood and front bumper and refinish it while it's still attached to the truck.
Old May 12, 2020 | 09:22 AM
4th Gear
Default Thanks
thanks will do if any one else has answers lemme know
Old May 12, 2020 | 09:27 AM
boston4's Avatar
Page 308 here has all of the instructions for installing the factory nudge bar.
http://www.fuddymuckers.co.uk/rtfm/D...s_(Export).pdf
Old May 12, 2020 | 01:22 PM
Frank4's Avatar
Attempting to strip and repaint your brush guard while it’s still attached is a comical suggestion. Have you looked where it is attached to the truck? I mean have you actually looked under the front bumper? There are some bolts under there, take them out. There might be some tabs under each headlights, unscrew those. BOOM
Old May 12, 2020 | 01:26 PM
boston4's Avatar
Previous owner on mine had a brush guard installed and couldn’t remove the bolts due to rust, so they cut it off with a sawzall. The front mounts are still visible in front of the truck. Might not be easy as you think.
Old May 12, 2020 | 03:12 PM
mollusc's Avatar
Be warned that if you take the Sawzall approach, you might regret it. I picked up a brush bar without the hardware and it took several months and a few hundred dollars to acquire a set.
Old May 12, 2020 | 03:13 PM
boston4's Avatar
Yeah. Definitely not the way to go, but I have the previous owner to thank.
Old May 12, 2020 | 03:38 PM
Frank4's Avatar
The OP hasn’t even found the bolts yet. And if they are rusted you can still get them out, you just might not be able to reuse them.
Mine has the same brush guard when I got it. Yeah, the bolts were rusted, did it suck getting them off? Yeah. Were they reusable? No.
Can’t believe someone would just hack the thing off and leave the mounts still attached, wow.
Old May 12, 2020 | 04:07 PM
mln01's Avatar
Wow. I'd use an angle grinder or something else to cut off the bolts if they were too rusted to remove otherwise before I'd take a Sawzall to the mounts. But first I'd try heating the nuts with a torch, even a hand-held propane torch.
There's no end to the geniusry out there.
DiscoRover007
Mar 19, 2012 07:13 PM
wekoho2
Oct 28, 2011 03:25 PM
DiscoSafari
Sep 19, 2011 03:03 AM
agthird
Sep 2, 2010 05:54 PM
Disco Alan
Aug 7, 2006 04:35 PM
