How does the 4wheeland drive Work
#41
Water pump leak - if out the front the pump is going and may wobble when running. Eats metal. Water pump has a gasket, then the front cover behind it has a gasket. If going into the front cover strongly consider doing the oil pump gears and timing chain at same time. If replacing pump you'll be money ahead replacing the viscous clutch also ($60 Chevy 2000 Express 4.3 liter w/o AC will fit).
#42
Its not that we are seizing an opportunity to beat up on you, its that your focusing on your traction control when you have a ticking time bomb under the hood. At the point the temp gauge moves any past center, and even before it begins to move you have already exceeded dangerous temps. Gets leaks fixed, get ultra gauge to monitor, then hook up to trees.
#44
#45
I think I might just sell this land rover fix it and sell it too many jackass dive them. And I don't want to be associated with those kind of people. Had a chevy s10 that could handle more and had less problems. In between y'all here and dick head disco mike, this website is about a joke ask one thing and still no one can explain it. I liked land rovers before now but I may just go buy me a ford or dodge. At least then I can have something dependable. And when metels get hot they expand not contract. So why would the steel sleeves move.
#46
#48
We've been honest with you x1scooterxx, some have been brutally honest. However, if you continue on a path of defamation and name calling you are not adding anything but garbage to the site. If it continues, there are consequences, even on this free membership site. Why don't you take a week and think about that? During that time work on your truck, read the shop manual, owners manual, etc. Moderators and most members on this site have pretty thick skins, and we are used to dealing with members with thick heads. But what we are really trying to do, despite your best efforts, is keep you wallet thick.
