How to find the ECU of my LRD I
i have no idea, im sure that theres a company like bg over there though. anywhere like NTB or, and i hate saying it but, Jiffy Lube have machines thatll do this. just be sure that its pressurized, not just suction. its the difference of say blowing shop air through a filter and using a vacuum on it, you get a lot more debris out with the shop air... by the way, and i didnt even check to see if i missed it, and this goes double for anything electrical, but please mention if the car is US spec or not. just as with this ECU, its behind the glove box here, somewhere thats right hand drive, it very well might be behind the steering column
exactly spike. my shop has a BG power flusher, that pushes pressurized fluid through the system, and you can set it up to reverse flush the system too. ive seen it fix a number of strange problems like this just by it cleaning up the valves, just fluching the fluid so you have new stuuf in there really wont help you much, take it in somewhere that can do a bg flush and give it a shot, hundred bucks or so which is nothing compared to just replacing it... and as a rover tech, i cant suggest disconnecting the abs, but it would be a cheap easy fix
i meant the abs ecu, as in the control unit that is behind the glove box, not the abs modulator, on a d1, the modulator(the one that has brake lines, not just wires) is just a slave, it does what its told and doesnt make descisions for itself, thats where the ecu comes into play, the ecu reads wheel speed, transmits that and if it sees lockup tells the modulator what to do. and yes, it can get confusing because of the number of ecus these cars have, but generally the engine ecu is refered to as an ecm, engine control module... either way, i agree that the abs ecu wont help, its much more likely for this to be a mechanical problem and not a electrical problem
The scanner showed constantly a ECU failure. My wife is a Pain in ... with this thing, she wants her truck to work properly.
What do you think Should I try with the ABS ECU, or you insist I should do a Big flush to the modulator, and discard any failure there.
I am not taking the truck to a dealer, cause they charge you just for breathing in their shop.
Thanks
Paul Grant
08-10-2014 12:29 PM
