How to fix Exhaust Leak...???
Old Apr 11, 2011 | 10:59 AM
logicmike44's Avatar
Default How to fix Exhaust Leak...???
I managed to find the source of my 'sputter', two small hole in my exhaust just after the O2 sensor.
Can this be fixed without welding ?
Old Apr 11, 2011 | 02:20 PM
tuck's Avatar
I'd try hi temp JB weld. It should do the trick, and if it does burn off, its not like it would be hard to re-apply.
Old Apr 11, 2011 | 02:50 PM
Bundu's Avatar
Banned
Welding is the best option.
Old Apr 11, 2011 | 08:13 PM
Wolf's Avatar
Welding is the best option, but if you do not have the ability to weld yourself then take it to a local muffler shop, these pin holes can cause more problems than you think. As long as the pipe isn't corroded and you have enough meat left on the bone then a decent shop should be able to weld for cheap. I would not recommend JB weld or a exhaust repair kit.
WaltNYC
Jul 27, 2015 02:24 PM
Juergen33911
Jun 19, 2013 12:49 PM
lsmit605
May 11, 2011 11:50 AM
DiscoIIBrandon
Feb 8, 2011 07:44 PM
lipadj46
Jul 8, 2009 07:41 PM
