How to get to the Transfer Case fill plug
Old Apr 10, 2014 | 06:07 PM
ralphobell's Avatar
For your next trick...get the fluid in there....That is lots of fun as well.
Old Apr 11, 2014 | 06:55 AM
ThisRoverGuy's Avatar
Oh yeah. I told my wife, "I just have to put a couple bottles of gear oil in and then put in a screw. Should be about 5 minutes."
God bless my wife, she's learned what it means when I say something on the Rover will take 5 minutes.
Originally Posted by Jared9220
Breaking the plug loose for the first time can be a pain in the *** if the T-Case has not been serviced regularly. If you start checking the fluid level on the regular and tighten the plug correctly then you should be able to just use the 1/2 ratchet next time.
I'm sure this will be the case. I had done the differentials the day before, and their fluid was pretty clean (looked to be royal purple in there). So someone had obviously serviced them recently (further indicated by the ease of the job and removing the plugs).
In contrast, the t/case oil looked pretty black. Obviously, that fill plug hadn't been out in awhile as well. And these owners wonder why parts go bad on them "but I serviced the truck regularly." Yeah, dummy, but you have to service everything!
Old Apr 11, 2014 | 08:23 PM
tuercas viejas's Avatar
The very best tool for removing that plug is this:-
https://www.google.com/search?q=serp...=isch&imgdii=_
It also comes in handy for doing serpentine belts which if course it was made for initially.
T/V
Old Apr 11, 2014 | 08:24 PM
ralphobell's Avatar
So which one is it?
Old Apr 11, 2014 | 09:39 PM
T/V
The black box contains numerous socket adapters one of which is a 1/2' male square.
Inserted into the ratcheting bar the fixed adapter handle connects with it and gives you about three ft of lever pressure to budge even the most stubborn plug loose. Since it is very thin it will slip underneath parking brake cable and give exact right angle contact with the plug.
Magic and you can check it all in about 2 minutes flat.
T/V
Old Apr 11, 2014 | 09:45 PM
ralphobell's Avatar
Thanks, I was confused because the link sent you to a google image search with all kinds of different serpentine belt tools.
Old Apr 11, 2014 | 10:52 PM
ScreamingLife's Avatar
I just did this the other day and the filler plug came out with no problem, it was the drain plug that was the issue. I had to soak it in WD40 before it would even budge. I did it with a wobble extension and it worked great.
As for how to get it in, I used one of these:
Amazon.com: Plews 55001 Lubrimatic Fluid Quart Pump, Fits Standard Quart Bottles: Automotive Amazon.com: Plews 55001 Lubrimatic Fluid Quart Pump, Fits Standard Quart Bottles: Automotive
with a copper tube bent to keep it in so I didnt have to bother holding it in.
Disconoobie
Oct 19, 2010 07:36 AM
josemex
Jul 31, 2009 09:58 AM
Disco Alan
Apr 21, 2009 06:22 PM
jrkstore43
Mar 2, 2009 08:27 AM
Phototone
Apr 7, 2008 03:59 PM
