How hot should my 2003 run if the ac on
Old Jun 26, 2015 | 04:50 PM
cornbreadj's Avatar
Default How hot should my 2003 run if the ac on
How hot should my 2003 run with ac on how hot is overheating when ac on it runs hot don't know what Iis rong
Old Jun 26, 2015 | 05:04 PM
Big Jim Swade's Avatar
Using my Garmin Eco Route connected to my ODBII port, I'm usually running around 208°F.
Old Jun 26, 2015 | 05:06 PM
cornbreadj's Avatar
My car is getting up to 220. It normally runs at 188 to 196. Ac on it just goes up.
Old Jun 26, 2015 | 05:10 PM
Dave03S's Avatar
Mine runs the same temp with the AC on or off.
Running the grey 180° thermostat
Old Jun 26, 2015 | 05:24 PM
cornbreadj's Avatar
I have 180 stat
Old Jun 26, 2015 | 05:25 PM
cornbreadj's Avatar
What temperature does it run at
Old Jun 26, 2015 | 06:56 PM
Is the electric fan in front of the radiator coming on when you switch on the ac?
Old Jun 26, 2015 | 07:38 PM
abran's Avatar
Under 200 is the sweet spot with AC on. I have a 2003 that runs at 195 max(180 t stat). 2004 that runs at 190 (inline t stat mod- 175).
Check the electric fans.
Old Jun 27, 2015 | 01:28 AM
Dave03S's Avatar
188.6 on the freeway, AC on or off.
197 at idle max, same with or without AC.
I frequently run in ECON mode but have tried turning it completely off just to see what the temp does... nada diff.
Read with Ultragauge.
Old Jun 27, 2015 | 06:45 AM
dgi 07's Avatar
You may want to check your electric fan dude....
