How to install cam bearings?
Old 07-26-2024 | 08:29 PM
evil_goat's Avatar
Question How to install cam bearings?
My new (used) bare block came, however it did not have cam bearings installed. What kind of tools do I need to install them? Can I continue putting the pistons and crank in the engine or do they need to be removed to install the cam bearings?
Old 07-26-2024 | 09:16 PM
you will need something like this YouTube has videos on the how
https://www.summitracing.com/parts/w...BoCsHgQAvD_BwE
Old 07-27-2024 | 12:50 AM
evil_goat's Avatar
Can I replace the cam bearings with the pistons and crank installed, or will I have to wait to replace the cam bearings before I put the pistons and crank back in?
Also, what is the difference with the ones that have diagonal oil groves on the inside. Are the ones without it bad?
Old 07-27-2024 | 10:55 AM
Bearings will frequently be journal dependent like a specific oil groove for a spot in the block.
I don’t see any reason you can’t do it with the crank and pistons installed. Just more weight to shift around as the last bearing if memory serves is installed from the back of the motor. So off the stand and on the hoist or some other thing to hold it
i don’t do them myself generally I have a good machine shop do it as aligning those oil passages can be tricky.
Old 07-30-2024 | 04:04 PM
acebroke1's Avatar
For lower bearings there is something you have to do on install .. they either go in dry .. or you grease them. I'm not sure which.
There is some thing you have to do.... but I can't remember .. You should find out what it is before you do it.
Old 07-31-2024 | 05:47 PM
evil_goat's Avatar
By lower bearings are you referring to the crank main bearings?
Vegasdisco2
05-31-2022 09:21 PM
Alex_M
05-04-2018 05:17 AM
Davis31052
11-15-2017 10:18 PM
Blacktt3z
08-09-2017 02:14 PM
Charlie_V
08-20-2015 10:17 PM
