Cam Bearings for Buick and Rover the same?
Old Nov 15, 2017 | 08:10 PM
Davis31052's Avatar
Default Cam Bearings for Buick and Rover the same?
So, being that the Buick 215 and the Rover 4.6 block is, or was the same, could a set of cam bearings be two way compatible. A finished set of Buick 215 bearings can be bought for less than $40 where as the Rover bearings are nearly $180. Just spit ballin’ here.
Old Nov 15, 2017 | 08:56 PM
Alex_M's Avatar
The cam did change when the Bosch brain came along because there was no more need to turn a distributor. Not sure if that changed anything else or not, nor am I sure what the specs are. Sure would be nice to get the cheaper bearings.
Old Nov 15, 2017 | 09:18 PM
KingKoopa's Avatar
Quite a bit of the architecture has changed over the years. Wouldn't surprise me if can bearing sizes/oiling positions have changed
Blacktt3z
Aug 10, 2017 07:32 PM
earlyrover
May 22, 2017 04:37 PM
suzukisam967m
Sep 19, 2013 11:30 AM
03discoman
Jan 29, 2012 08:29 PM
rambo
May 17, 2006 08:02 PM
