How long can you drive it with a slipped liner?
Old Feb 20, 2021 | 08:34 PM
  #41
gleepglorp's Avatar
Originally Posted by mollusc
Head gasket sealants only cause more trouble down the road. Don't do it.
I have no idea how much a mechanic would charge to do a head gasket job. I'd get a second opinion from someone who knows Land Rovers before pulling the trigger on it though.
So I have an odd report.
Earlier today I drove the car a little bit and there was NO white smoke. I topped off the coolant before driving it too... Could this still be indicative of a blown HG????
Old Feb 21, 2021 | 05:16 AM
  #42
mollusc's Avatar
You've asked if white smoke is indicative of head gasket failure.
Now you're asking if no white smoke is indicative of head gasket failure.
You seem to be fixated on that one idea, but I don't think you know enough about how an engine works to understand some of the guidance you have been given. Maybe it's just cold where you are so the white smoke is normal, and needing to top off the coolant is because you need to replace the reservoir cap,
Find someone who knows these vehicles and these engines to give you some straight information.
Old Feb 21, 2021 | 07:21 AM
  #43
gleepglorp's Avatar
I apologize I am not very mechanically inclined as I am learning more about engines... no need to get angry
Old Feb 21, 2021 | 07:36 AM
  #44
mollusc's Avatar
I didn't mean to imply that I'm angry. Trying to say that it appears that you have grabbed hold of an idea and could benefit from some better in-person guidance.
Old Feb 21, 2021 | 07:47 AM
  #45
gleepglorp's Avatar
Yeah, I'll get an in person opinion.
Old Feb 21, 2021 | 11:05 AM
  #46
Dave03S's Avatar
I just remembered the last time I heard what I assume to be an actual slipped liner... could have been something else... But this truck, a 4.0, literally sounded like someone hitting a hammer on an anvil. And not some wimpy hammering either... It was much louder than the engine and reverberated off nearby buildings. The guy drove off like nothing was wrong.
Your video does not sound like that sound, just saying.
Old Feb 21, 2021 | 11:43 AM
  #47
Xanthro's Avatar
It does not sound like a slipped liner, and the timing is not indiative of a slipped liner,as the sound appears mhen you engine is cold. Slipped liners usually start making sound when your engine is hot.
Your engine appears to be running a bit rough, but the cause of that could be any number of reasons.
For example, how long had the vehicle sat unused before you got it? Discovers don't like to sit unused, and that roughness could work its way out by driving it some.
Start with the easy things, get fresh oil, new coolant of the same type that is there already. Flushing all the Coolant to switch types can be hard. Then drive the a 100 plus miles and report back.
Also, take a picture of your throttle plate heater, they often leak if you stand in front of your vehicle, the throttle will be on the right side of the engine on top with the two cables attached. Directly under where the two cables are attached is the throttle heater plate.
Old Feb 21, 2021 | 12:12 PM
  #48
mollusc's Avatar
I wonder where the OP is, in case someone can offer some suggestions about decent places to take the vehicle?
Old Feb 21, 2021 | 01:36 PM
  #49
gleepglorp's Avatar
I live near Asheville NC I know of a rover specialist that are some of the best around here.
I still need to get them to look at the car once I get everything tightened up this tuesday with this other mechanic.
I have a few things being done to it like the coolant reservoir being replaced, o2 sensors are shot and need to be replaced, and the steering shock is bad.
other than that im gonna bring the car to the rover specialists in the future.
Old Feb 21, 2021 | 01:47 PM
  #50
Richard Gallant's Avatar
Why are you replacing the coolant reservoir ?
