How long to run ABS while bleeding brakes?
Old Feb 23, 2022 | 01:30 PM
Discorama's Avatar
Better use a relay, switches won't last long at that amperage. And the method needs no suction, since there is pressure as soon as the ABS pump is activated. I use a push button in one hand (requires long wires so it reaches to all four wheels) and a wrench in the other hand. Press the button, open the bleeder, bleed, close and then release the button quickly.
Old Feb 23, 2022 | 04:10 PM
SWM's Avatar
SWM
Flush went well but had warning lights after the flush test drive using HDC to buzz the fluid around
https://landroverforums.com/forum/di...-flush-110904/
Old Feb 23, 2022 | 05:29 PM
Discorama's Avatar
Did you install a new master cylinder?
Old Feb 23, 2022 | 05:48 PM
SWM's Avatar
SWM
No, just a basic brake fluid flush. All fine before, no warning lights
Old Feb 23, 2022 | 11:11 PM
Discorama's Avatar
Check if the ABS relay sits properly. Check for blown fuses. Bleed again and check for trapped air. Unfortunately light's will not go away from that. That needs to be reset with a nanocom or similar tool.
Same happened to me after excessive HDC. I bled the brakes and reset the ABS, the problem never came back.
Old Feb 24, 2022 | 07:45 AM
SWM's Avatar
SWM
I have this generic code reader and an ultragauge so I'll see if it will give me specific codes. Then I'll check those few things and give another quick bleed and cross my fingers.
lilherc
Jun 7, 2019 08:51 PM
nmacej
Dec 28, 2017 07:46 AM
MacRoadie
Feb 21, 2017 09:58 PM
jamestfl
Jan 16, 2017 02:29 PM
bostongrun
Oct 30, 2015 11:33 AM
