How much?
Old May 6, 2013 | 04:20 PM
ZGPhoto's Avatar
Default How much?
How much coolant will I lose if I replace my thermo tonight? I'd like to get it done now, but don't have any coolant here at work to replace the amount I lose. Replacing it with the 180 degree genuine stat, PEL500110.
http://landroverparts.roversnorth.co...ER-180%C2%B0-F
Old May 6, 2013 | 04:25 PM
1/2 gallon. On a D1. More on a D2. Go to corner store and get a gallon of distilled water. And takes some pictures of you changing that stat, cameras still have self timers.... probably just see your feet sticking out from under the truck.
Vise grip pliers on hose and rags help also. Or C clamp and some wood strips.
caymandrew's Avatar
When I swapped mine out I lost between .75 and 1 gallon of fluid just from draining out of the hoses connected to the stat. That leaves what, 1 gallon still in there? Should be enough if you just refill with water to get you to the store for some coolant. Be sure and have two or three pans ready, it spills out underneath in all kinds of directions!
Old May 6, 2013 | 04:28 PM
You have plenty of space with those tall tires, just a big pan to catch it and put it back in. Open one hose and let it drain.
Old May 6, 2013 | 04:30 PM
ZGPhoto's Avatar
Haha thanks guys, I'll figure out how to use a camera and let you know.
Old May 6, 2013 | 04:34 PM
caymandrew's Avatar
Just for a note, to get to the clamp on the bottom of the t-stat I had to first remove the upper two clamps, and bend the stat completely down crimping the lower hose to expose the clamp (which pores fluid everywhere) Have fun!
Old May 6, 2013 | 04:35 PM
coors's Avatar
It's all you Zach.
Old May 6, 2013 | 06:05 PM
ZGPhoto's Avatar
Haha Andrew- I did that out of necessity but was still a pain. Here are some photos.
Old May 6, 2013 | 06:06 PM
ZGPhoto's Avatar
I realize the photos aren't great, partially because my fingers were in so much pain from the tight spots.
Old May 7, 2013 | 11:41 AM
SuperSport's Avatar
When I did mine, it was so incredibly difficult, until my hand and the wrench both bent in the correct position, and voila, the clamps came right off. I can't remember what bend that was, but it was simple when it happened.
I'm sure it was some sort of Yoga move.
I remember pulling the fuel line from my 99 XJR Fuel Tank and same thing, the correct angle and it's off. Otherwise, you could break an arm up in there on the XJR.
