How much crank pulley wobble is normal? [video attached]
Old May 24, 2017 | 12:06 AM
OffroadFrance's Avatar
Originally Posted by Jeff Blake
I can't find any definitive info on the 'net about the weights. Everyone says something different, and its dependent on the make/model of the engine as to how the rotating assembly is balanced. I'll try calling some indie shops I guess.
As for the holder tool, yeah I know of those solutions. When I rebuilt it, I jammed a block of wood in the crank web. Worked ok. I don't want to have to drain the oil and pull the sump just for this. I need to torque it, not break it loose, so using the starter is a no go.
I found the official tool on eBay, and it's not the worst deal I've ever seen:
Land Rover 300Tdi, 200Tdi / Jaguar Crank Locking tool (LRT 12 080) (VS4985) | eBay
other sites sell it for 200$+
It's the right tool number... but it has 4 bolts, v8 pulley only has 2. I suppose this is a multi-model tool. The td5 requires 340 foot lbs (!!) as opposed to the v8's 200. 4 bolts is probably to accommodate that extra torque
On a TD5 there is a locking pin that inserts into the bellhousing and through the flywheel but I don't know whether it's the same on a V8.
Old May 24, 2017 | 07:23 AM
dgi 07's Avatar
Originally Posted by chubbs878
...... the techs rarely get feedback on their work. They only hear back when the owners car doesn't make it home from the shop. Get my drift?
AYE, Some of us resemble that statement!
Old May 24, 2017 | 12:17 PM
Jeff Blake's Avatar
From land rover:
Good morning Jeff.
The OEM LGH000060 balancers are pre balanced from the manufacture.
Hope this helps.
Randy Johnson
Parts Manager
Old May 24, 2017 | 02:45 PM
From land rover:
Good morning Jeff.
Hope this helps.
Randy Johnson
Parts Manager
Told ya Jeff
IMHO Jeff, your pulley is good for a 1000 mile trek at reasonable speeds towing provided you check the torque on the bolt first.
Old May 24, 2017 | 03:05 PM
Jeff Blake's Avatar
Originally Posted by OffroadFrance
Told ya Jeff
Right you are! Thank god I don't have to get the whole balanced just to replace a pulley.
Agreed, I feel pretty good about embarking. Replacement won't get here in time anyway.
Now to go make a rainjacket for my drill so I can extract the busted tranny drain bolt.
kristofferzen
Nov 7, 2015 07:14 PM
danvlarsen
Apr 24, 2013 04:09 PM
94svt50
Apr 9, 2012 04:36 PM
0304Disco
Sep 1, 2011 03:28 PM
CBK
Apr 2, 2011 10:07 PM
