How often do you change out your brake pads and rotors?
Old Nov 22, 2017 | 04:26 PM
  #21
KernowDiscovery's Avatar
Replacing Watts Links/Bushings can be a real PITA. The trick is to start drinking early (like the day before) and often.
Oh, and a lot of swearing also helps!
Not a big drinker but good to know OverRover Swearing on the other hand.. I've got that down haha. I'll probably leave the bushings to the professionals, may be a bit out of my league. I'm happy to have a direction though as to what may be the issue.
Old Nov 22, 2017 | 04:27 PM
  #22
If it is the watts bushings, I'd buy the whole unit that mounts to the axle housing. There are two more bushings, on each end of the control arms, but mine were good. I pressed in the bushings at work, with a 20 ton press, and I was very unhappy with the quality of the bushings I got from Atlantic British. The center bushing pressed in easily, but one of the smaller ones cracked (plastic outer shell) while installing...the other small one went in easily.
Whole assembly on ebay. There are a couple more, ranging in price, this one was the closest.
https://www.ebay.com/i/111506571147?...D1372039321655
Brian.
Thanks again Brian. I'll take a looksee this week, but it sure sounds (and feels) like that is the problem. I'll grab the outer bushings too while i'm at it. may as well have it all done at once
redrover99
Jan 10, 2016 08:17 PM
daxter1987
Jul 24, 2015 07:59 AM
ZB-30
Jan 18, 2014 07:28 PM
chris006
Apr 29, 2013 12:00 PM
kcferna
Jun 24, 2009 03:39 PM
