How to program remote?
Old Nov 1, 2009 | 03:48 PM
alanroberts50's Avatar
Default How to program remote?
A couple of years back I purchased a 2 button remote for my 98 D1 as the truck didn't have one. The remote seems genuine and has "Lucas 3TxB" on the back. At the time I tried using the program instructions that came with it (they are the same as in the RAVE) but nothing happens. I don't get the beep or flashing LED after carrying out the procedure for initialising the remote handset. The alarm is working perfectly with the key.
Any suggestions? here's the procedure from RAVE that I use. I tried it sitting in the car and also standing alongside with the drivers door open as the manual is not specific.
1)ign off, doors unlocked, bonnet (hood) closed
2) steps 3-9 to be done within 8 secs
3)switch ign on
4)switch ign off
5)lock doors
6)unlock doors
7)release bonnet (hood)
8)switch ign on
9)switch ign off
Then it says hold the remote button (doesn't say which one) until LED flashes on dash. Never happens. I metered the battery in the remote and it's ok.
Old Nov 1, 2009 | 05:04 PM
mcleoddude's Avatar
I didnt know you could do it your self i brought my 97 to a rover mechanic and he said he had to hook it up to there t4 equipment but they did it for free cause it took them 30 min. after my app. to even get to it. If you figure it out post how you did it mine is pretty beat up.
Old Nov 1, 2009 | 06:02 PM
Well the guy that sold me the remote said the RAVE procedure worked correctly on everyone elses that had done it so I think the problem lies only with me. Try following the procedure in RAVE and let me know.
Old Nov 1, 2009 | 08:37 PM
Follow the RAVE, it is also in the owners manual.
Old Nov 1, 2009 | 08:41 PM
Thanks Spike but as I mentioned in my initial post I did follow the RAVE procedure and nothing happens at the end when I press the remote button to sync it, no red LED.
Old Nov 1, 2009 | 08:51 PM
If you lock the drivers door with the key does the red LED come on?
Old Nov 2, 2009 | 09:47 AM
Yes, and the hazards flash just as they are supposed to.
Old Nov 2, 2009 | 09:53 AM
Ok, so the alarm is working properly then.
I am out of idea's, sorry.
Old Nov 2, 2009 | 08:41 PM
kenk's Avatar
Mine does the same thing, alarm works fine, but will not go into learning or program mode(whatever its called) following that procedure. Its the same procedure i found in about 4 diffrent spots.
When you go through the steps, does it matter if you lock/unlock with the inside lock button or use the key outside?
Old Nov 3, 2009 | 11:11 AM
I thought about that too but it would be kinda tough to do all that in 8 seconds if you also had to open and close the door from the outside and then hop in to insert the key in the ign. think I will try it using 2 keys, one already in the ign ready to turn and one in the door lock on the outside. I'll let you know but I don't hold out much hope.
