How to remove fan clutch from fan on '03
Old Aug 10, 2013 | 09:51 PM
jrod770's Avatar
Default How to remove fan clutch from fan on '03
I just swapped out water pump for the bronze impeller version, replaced hoses, and put in the 180 stat. While I'm at it I'm changing the fan clutch. I got the GMC safari van, without AC unit. My only question is, How do I get the old one off the fan? I don't see any bolts or screws that can be removed to separate the clutch from the fan. Am I missing something, or am I screwed because I have an '03 that the two won't separate?
Thanks for your help.
Old Aug 10, 2013 | 10:59 PM
jeffh's Avatar
you do not.. on the 03-04 they are not replaceable.
Old Aug 10, 2013 | 11:51 PM
jfall's Avatar
What??
You replace the fan clutch and fan as a unit on an 03?
I am glad to learn this..
I have a 2001 so they are two units..
Interesting how things change year to year.
I wonder when the LR3 will be affordable to the common man.
And then this Discovery II forum will be like the Discovery I forum. Not soo busy.
And the LR3 forum will pick up in posts.
Old Aug 11, 2013 | 07:37 AM
Jrod, because of the cost of a new fan, you have 2 options, either buy a good guaranteed used one from Paul Grant or buy an early D2 fan and clutch, replace the used clutch with the one you already have and us that. Fan looks different but it works well.
You could also use a $10 boneyard GMC fan slightly modded.... or a D1 fan or a Rangie fan
Old Aug 11, 2013 | 08:10 AM
jrod770's Avatar
It figures. Oh well, another call to Paul. Thanks to everyone for their help.
jafir
Feb 10, 2017 11:08 AM
indianadisco22
Aug 10, 2014 03:36 PM
Thatdudeuno1
May 1, 2012 05:10 PM
dino109
Jan 1, 2012 03:38 PM
rover1978
Sep 26, 2009 09:05 PM
