How to replace exhaust manifolds???
Hi All,
I'm looking to replace my exhaust manifolds on my 02 Land Rover Disco II and wondering how I can do it myself...If any one can provide me with a how to it'd be appreciated.![Roll Eyes](https://landroverforums.com/forum/images/smilies/Yrp3aj7.png)
Also planning on replacing all four of my shocks so if any one can provide a how to on that as well it be great.
A.
A.
This video makes suspension look slightly more easy than it really is but explains it well.
YouTube - ‪2in OME install‬‏
if they aint broke don't replace them. but if they are noisy from loose studs then heat the truck up and take out the studs and use a 12 point 12 mm socket to get them off.
but heres a trick, use a stud puller and a torch to get the studs out. then use a thread chaser that is 8 mm and new studs and replace everything. its recommended you do both at the same time because you may have issues getting the manifold back on by itself.
@Mike
First, how many miles on your truck, do you go off road much?
It has about 108K miles on it. No, I have the truck for less than 3 months.
What is wrong with your manifolds?
There is a noise that sounds a lot like an exhaust leak when I press on the accelerator with the car in motion - which leads me to believe that the manifolds or the manifold gaskets have to be replaced - plus there is whining/whistling noise that is coming from the driver's side wheel...Any suggestions??
![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
If you are replacing your shocks and you go wheeling much, you should replace your springs also since they are warn out.
No I dont going wheeling at all, but there is a bit of squeaking on the front and back shocks...also at the speeds of 50mph and higher the truck begins to bounce a great deal on a flat smooth road.
Who's shocks are you planning on using?
I have no idea who I should go with, but I am taking suggestions...I would like my truck to ride a lot like the Lincoln Towncar where you almost don't feel any of the bumps.
Street Wolf
06-24-2011 01:59 AM
Tastang
11-10-2007 09:53 PM
